11-10-2006 06:34 AM
11-13-2006 05:38 AM
I don't have a camera to recommend directly, however one of our alliance members, Amfax ( http://www.amfax.co.uk/ ) has done a similar application already. (Ask for James)
I'd suggest you start by talking to them.
Sacha Emery
National Instruments (UK)
11-13-2006 05:42 AM - edited 11-13-2006 05:42 AM
I should have said - you need to work out what depth of field you need (if any - if you're backlighting the holes then is there going to be any light flaring = single point light source etc) and what resolution you need to measure the holes to.
Also, how are you planning to move the item under inspection around, or do you need a wide field of view?
What speed do you need to work at aswell? (Frame rate to include your analysis time will be affected by the image size)
That way you can work out the lense options you need and the resolution of the camera required and also potentially which connecting bus you need.
Hope that helps
Sacha Emery
Message Edited by SachaE on 11-13-2006 11:43 AM
