Machine Vision
camera sensing temperature
Dear all,
i'm trying  to develop an algorithm to use ordinary USB camera to read a bimetallic thermometer's needle position so that it can recognize the real-time temperature. Does anyone have any idea how to do it or have ever done similar things before? please give advice.
Many thanks
Brad
(4,281 Views)
Hey Brad,
First of all, does your USB camera support direct show? Starting in August 2009, Vision Acquisition Software officially supports DirectShow imaging devices as part of the IMAQdx driver. Then you would use Vision Development Module for image processing
Andy Chang
(4,267 Views)
Once you acquire images with IMAQdx, VDM includes an example that shows you how to process them to read a meter.
Message Edited by BlueCheese on 02-05-2010 01:29 PM
(4,261 Views)
Hi there,
Thanks for your info.
Could you please give me the source file for the METER EXAMPLE? I don't have Vision Development Module installed on my PC.
(4,233 Views)
You wouldnt be able to open the VI if you dont have VDM installed... But here it is in 2009
Andy Chang
(4,222 Views)
Hi there,
unfortunately, i cannot run the program due to my labview is 8.6 version. i'm wondering if you do have the 8.6 compatible version?
Cheers
(4,211 Views)
Accepted by auckland
Here it is in 8.6
Andy Chang
(4,195 Views)
