Machine Vision
camera 1426
I'm working with a 1426 framegraber and a Sony U1000 camera. What I want to do is to control the exposition time during an acquisition. I m able to do that using the IMAQ Set Camera Attribute.vi and a Snap acquisition. But if I want the do a Grag acquisition the following error appears:
NI-IMAQ:  Cannot perform request; acquisition currently in progress.
What I don't understand is that it seems to work in MAX.
So is it possible to change the exposition time using the camera attribute during a grab acquisition?
Or if not, shall I try to use a external pulse trigger to control the exposition time?
Thanks in advance, best regards
(3,323 Views)
Hi Gil51,
Due to the way camera files in IMAQ work, it requires the acquisition to be stopped to modify camera-based settings. One alternative is to find out the serial strings needed to configure the exposure time and send them manually using the IMAQ Serial Read/Write VIs. Another option is to use an external trigger as you mentioned. You might be able to use the IMAQ board to send a pulse train with the required timing to get the exposure time you want.
Eric
(3,315 Views)
