Machine Vision
Ethernet Server with VBAI 3.5
I have already some problem with triggering the inspection and selecting the inspection by TCP.
I have different solution. I could use 2 differents socket (1 for Select Inspection and 1 for Triggering the inspection). I think VBAI 3.5 is not able to support 2 master or 2 slave TCP Ethernet device.
I have tried to use 1 master and 1 slave. This solution is working one time, and no more.... I have tried to restart the application, the computer, but It doesn't work anymore.
First question : VBAI 3.5 is able to work with 2 master or 2 slave Ethernet device ??????
Second question : VBAI 3.5 is able to work with 1 master and 1 slave Ethernet device ??????
Third question : When I send 3 bytes after opening the port from my application (C++), VBAI takes approximatively 10 seconds to receive those 3 bytes. After this the connection is working well.
Thank you in advance for this answer.
F.Michel
(3,972 Views)
Hello Mr Michel,
I tried to figure out, what exactly the problem is, but it is not really clear to me.
To select the inspection you'll find a descriptionif you go to View > View Complete Setup > Select Inspection
 What do you mean by "I have tried to use 1 master and 1 slave"? VBAI can be set up as master or slav, but there can be only one master and multiple slaves.
Maybe you could tell me a little more about your application and post some example project so I can understand your problem a little bit better.
Andreas Stark
LabVIEW Lead @ Rocket Factory Augsburg
(3,932 Views)
Hello AndreaS,
Sorry if I'm not very clear.
Ok. I would configure VBAI to be one master and one slave. I need two different TCP communication between the vision system and the complete machine.
I have tried to use one TCP communication for the select inspection and another TCP communication for triggering the acquisition. But this solution didn't work.
My question is : VBAI is able to work with one master and one slave TCP device together ????
F.Michel
(3,930 Views)
So you have two applications that communicate with VBAI over TCP/IP? One application is a Master and VBAI is the slave and for the second application VBAI should be the master and the application is the slave?
Andreas Stark
(3,926 Views)
Correct, but there is not TWO applications but only ONE with two socket opened.
Did you know if VBAI is able to manage an application like this ?
F.Michel
(3,924 Views)
You should be able to configure two TCP connections, one as master, one as slave in Tool > Communication device manager.
Let me knwo if that solves the problem.
Andreas Stark
(3,922 Views)
