12-18-2008 08:27 AM
hi, i am using vision developement module 8.6 in combination with VS 2008
i have the following problem
I have a geometric match method to match some object, i want to draw a ROI-Rectangle around the found object and search in the new ROI for another geometric pattern
how can this be done in c#?
im hardly looking forward for your repl
thank you very much 😉
12-18-2008 10:27 AM
You can use the CWIMAQGeometricPatternMatchReport object after calling the MatchGeometricPattern method and use the CWIMAQGeometricPatternMatchReportItem property which has the BoundingPoints property w/c are the coordinates of the corners of the rectangle surrounding the match
Check the cwimaq help file for more information.
Riscoh
