Machine Vision
background extraction
I am doing a project about image process. Can I use LabVIEW to do adaptive background extraction? How can I do it in  LabVIEW? Thank you very much
(3,309 Views)
Shaun,
There is no built in function to in LabVIEW or the Vision Development Module to do adaptive background extraction.  Using the Vision Development Module though, you could write a fairly simple algorithm to compare 2 images and then throw away pixels that were identical within some threshold.  For more information, check out the link below:
NI Vision Development Module
Luke H
(3,295 Views)
