Machine Vision
autothreshold value
Hi.
Currently, I'm doing an image processing using IMAQ Vision (LabVIEW 2010) to inspect corrosion in pipeline.
I successfully detect the corroded area by using IMAQ AutoBThreshold 2. May I know where I can find the exact value of the threshold used in the function?
In my report, I need to state the threshold value to strenghten my result.
Thank you.
Smiley Happy
(4,486 Views)
Accepted by nadiah
you can determine the threshold values with "Threshold Range Out" using "IMAQ AutoBThreshold 2 VI".
Please see the attached code - the output "Threshold Range Out" is used for manual thresholding and it produces the same results.
If you run the example without modification, the values from 88-255 produce white regions (1 or 255 in this case) and values from 0-87 black regions (0). So, your threshold vlaue in this case is 88 (88 inculded).
I hope this helps.
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(4,476 Views)
Yup. I got it. Thanks Klemen! Smiley Happy
(4,454 Views)
