Machine Vision
acquire from PCI 8254R
how to aquire data from PCI 8254R using LabVIEW?
Can I manage without the FPGA module ( I don't need to configure Inputs and outputs)
I think that I need IMAQ library .If yes . Where can I find it?
please send me example
(3,325 Views)
Accepted by Sadok
Hi Sadok,
If you are trying to acquire images from your PCI-8254R, you can use the examples in Example Finder.  Example Finder has the ability to limit the examples based on which ones will work with your specific hardware.  For more information on how to do this, check out this KnowledgeBase: Where Can I Find LabVIEW or LabWindows/CVI Example Programs Specifically for my Hardware?
These examples will require the IMAQ 1394 driver. This driver requires an activated license for Vision Acquisition Software, which you can purchase here: NI Vision Acquisition.
Hopefully that helps you out.
Stephen Meserve
(3,306 Views)
