Hello I have two ATE-Systems. Both have the same devices. Except the Industiral-PC and operationg System. One has Win98 the other has Win2000
In my test app, wich runs under Testand 2.0 and Imaq 2.6, I am doing pixel comparing from desired to actual picture. It is working fine, but under Win2k the function takes almost 2sec and under Win98 just a few milliseconds.
I think the NI-Function imaqGetPixel will cause this.
I can't tell you why the time is different, but I can suggest a different way to code it that might make a difference.
I would consider extracting the entire arrays as 32 bit integer blocks, then loop through the arrays and compare the 32 bit integers as a whole. You might be able to map into the image storage to get to the arrays to avoid making a copy.
Now I had time to take care about this problem. Thanks for your usefuls hints (Egg of Columbus). I have placed them in my code and now on Win2k and Win98 I have the desired behavoir.
So my result is that imaqGetPixel is much slower under Win2k.
So if you have no idea I will post this message once again to make more attention to this problem
Greetings from the Lake of Constance (Germany) Juergen
