09-27-2007 09:03 AM - edited 09-27-2007 09:03 AM
Message Edited by sammamishmac on 09-27-2007 09:04 AM
09-28-2007 01:54 PM
09-28-2007 02:24 PM
Hello Travis,
Thanks for the reply. The problem I am encountering is precisely what is described in the first link you provided. I've done all of the things described there previously, but I decided to try one more time. I closed every application except Labview and terminated every process I could, including all NI processes (there are a bunch). I loaded my application and then ran a memory defragmentation program. It said that I had a full 2GB of contiguous memory. I had a total of 20 processes running with a very small memory footprint.
Now, I called IMAQ SetImageSize with X resolution and Y resolution set to 32539. The error "IMAQ Set Image Size Not enough memory for requested operation" error is displayed. If I decrease the values to 32538, no problem. I've tried this on 2 different computers running XP pro, both with 4GB ram installed. Same result.
Best Regards,
Ron
10-05-2007 04:59 PM
Hello Ron,
I have spoken with the Vision Product Support Engineer about this issue in hopes of finding any other suggestion to offer you, but the KnowledgeBase document linked in my earlier post truly is our only resource on this particular error. The Vision Product Support Engineer explained that the problem is not with LabVIEW or NI-Vision; the operating system is simply not allocating a large enough piece of contiguous memory.
Best Regards,
T. McCarty
