Machine Vision
Vision's CoreUtilization property
Hi
I found a the CoreUtilization property of the Imaq Vision component.
I cannot find any documentation on this. Does is set the maximum no of cores used? My current software runs on a Quad core so should I set it to 4? What happens if set to 4 and the PC just has 2 cores?
Bestbier
Message 1 of 8
(4,469 Views)
You mean IMAQ Multi-Core Options VI?
If so, then normally you don't need to call this function, because by default all available cores will be utilized. This function nesessary if you need to reduce overall CPU load (for example, you have quad core, but would like to use only two for Vision application, the rest will be available for you).
Otherwise rememer, that not all IMAQ functions are optimized for MultiCore yet.
Andrey.
Message 2 of 8
(4,461 Views)
Hi Andrey
Thanks for the info. I just saw the property and wondered about it.
Bestbier
Message 3 of 8
(4,459 Views)
Welcome!
With greetings from Ahrensburg ;),
Andrey.
Message 4 of 8
(4,456 Views)
Ahrensburg - That's a nice place! I was there last year in September for some training. Much greener that where I am from in South Africa.
Message 5 of 8
(4,452 Views)
When you will (if you will) visit Ahrensburg for the next training, then don't hesitate to visit my office, located in the same building 😉
Andrey.
PS
Sorry for everyone for offtopic.
Message 6 of 8
(4,450 Views)
Sorry that we are off the topic.
I might be back. How do you know which building I went to? I know Ahrensburg is small, but it's not that tiny.
Bestbier
Message 7 of 8
(4,447 Views)
Because I working with X-Ray and can see through ;). By the way my e-mail in my profile.
Andrey.
Message 8 of 8
(4,442 Views)
