Machine Vision
Vision builder Inspection Migration to LabVIEW
I have migrated my Vision Builder Inspection to LabVIEW. I am using labVIEW and Vision Builder 2015 versions. After the inspection in loaded in LabVIEW I am not getting the expected results.
I have an Image Acquisition step followed by Vision Assistant to convert the Image to gray scale and then a Match Pattern step followed by a Caliper and Calculator. I am getting results(Image) with the caliper data. The Match Pattern bounding box doesn't appear and the result says failed inside Match Pattern code.
The Inspection is working properly in Vision Builder though.
I have attached the screen shot for both.
Hope the question is clear.
Please let me know why this is happening.
Swettha
(2,630 Views)
Accepted by topic author swethaRao
Solved it. Created a new inspection migration and it's working
(2,589 Views)
