Machine Vision
Error -1074395261 while multiple geometric patterns matching
Dear NI folks,
I'm trying to implement Multiple geometric patterns matching and have created three valid image templates via Vision Assistant.
But when I run the design, each time I got an error after several seconds, sometimes 10s and sometimes just 2s.
The error number is 1074395261, which means "An internal error occurred while attempting to access an invalid coordinate on an image."
Does anyone know what is wrong with my design? Is it a problem with my image templates?
I attach my templates and vi below.
Thank you!!!
(2,643 Views)
Have you tried using an example? Or trying to make only one recognition?
What has been the troubleshooting you have done?
(2,592 Views)
Hi azp7,
yes, I used an example called "multiple geometric patterns matching".
For troubleshooting, I took pictures of my targets from different positions and converted them to image templates. But the error still appeared. Currently, I don't know what else I can do.
(2,586 Views)
