07-03-2008 09:14 AM
07-04-2008 04:25 AM
Hi, Cabman,
I haven't experience with TestStand, but its not true "...that Vision Run-time licenses only work if the LabVIEW VI is compilied into an executable...". Technically almost all Vision VIs perform the DLL calls to NIVision.dll/NiVisSvc.dll. Vision Runtime will deploy these DLLs and the license. Do you have installed Vision Run-Time (vision71rte.exe in your case) on the target machine?
07-04-2008 09:17 AM
Ok, maybe I'm mistaken. It's been a while since I tried this.
I think I remember now the problem was that the un-compiled vi would not check out a run-time license from our VLM server. I had to have the Vision development system installed and activated for it to work.
07-07-2008 03:07 PM
07-14-2008 05:19 PM
07-15-2008 02:54 PM
