Machine Vision
Vision Assistant shows incorrect pattern matching results for some images
Environment:
Windows 8.1
LabVIEW 2018 SP1 f4 - 2020
Vision Development Module 2018 SP1 - 2020
Steps to Reproduce:
  1. Download all attached files;
  2. Open the script and the test image in Vision Assistant;
  3. Switch to Pattern Matching step of the script;
  4. Note a false match in the upper-right part of the image;
  5. Double-click the Pattern Matching step.
Expected Result:
Pattern matching results are the same in preview mode and edit mode.
Actual Result:
Pattern matching results in edit mode are different from preview mode. Edit mode shows a correct match.
Reported to NI with SR #7812172.
(1,950 Views)
NI Technical Support wrote:
Bug Report created: 1085591.
(1,902 Views)
