Machine Vision
Pattern matching can lose some matches when used with some advanced options
IMAQ Match Pattern 4 VI can lose some matches with an appropriate score when used with some advanced options (Max Pyramid LevelMatch List Reduction Factor).
This bug is somewhat similar to CAR #718023 listed in Known VDM Issues (archived), but relates to Pattern Matching rather than Geometric Matching.
The image was taken from this online camera using DirectShow wrapper.
Environment:
Windows 8.1
LabVIEW 2018 SP1 f4 - 2020
Vision Development Module 2018 SP1 - 2020
Steps to Reproduce:
  1. Download all attached files and open the VI;
  2. Run the VI and make sure there is a match found with score of 866;
  3. Increase the Minimum Match Score parameter value to 550 (you can scroll the mouse wheel up over the field);
  4. Run the VI.
Expected Result:
The match with a score of 866 is still found.
Actual Result:
No matches found.
Workaround:
Change one of the following advanced options:
  • Lower the value of Max Pyramid Level;
  • Lower the value of Match List Reduction Factor;
  • Set Process Border Matches option to 1 (True).
Reported to NI with SR #7812156.
(1,641 Views)
NI Technical Support wrote:
Bug report created: 1085588.
(1,591 Views)
