Machine Vision
Vision Assistant capture size 520X458
I am using Vision assistant with a NI PCI-1409 capture card. When I view a snapshot or continuous video the resolution displayed is only 520X458, but the source S/B 640X480. The top and left side of the image is being cut off. When I load a Labview example to snap a single image, I get 640X480 resolution. Does anyone know how I can get Vision Assistant to display the full image?
Howard Spec
CMC Electronics
Canada
(3,557 Views)
See this thread. http://forums.ni.com/ni/board/message?board.id=200&message.id=5197
It states that there is a bug in Vision Assistant 7.1. that is fixed in Vision Assitant 7.1.1.
If you are using VA 7.1, you will need to get an upgrade to 7.1.1, although I couldn't find it anywhere in the "update and patches" download page. I'm using VA 7.1 also, and am having the same problem. I emailed my local NI rep last week, but haven't heard a word from him. You know what they say about "service after the sale"!
I hope this helps you.
Dan Thomas
(3,548 Views)
Hello.
The best way to get this 7.1.1 version of Vision Assistant is to call our main inside sales number:
(800) 531-5066
Our inside sales folks can get the updated CD shipped out to you right away.
Colin C.
Applications Engineering
Colin Christofferson
Community Web Marketing
Blog
(3,540 Views)
Thanks for all the help. I solved the problem by downloading and installing the latest version of NI-IMAQ (Version 3.1)
(3,536 Views)
