Machine Vision
ROI descriptor causing error
I have generated an array of ROIs (roi descriptor of circles) and wanted to chagne the radius of the circles. So I have a for loop passing in the array and changes the radius one by one using Convert ROI to Annulus>change the value>Convert Annulus to ROI back to ROI descriptors again.
The result however is rather unexpected. The output is wrong. The values for global rectangle are changed from eg 51 to -2147483587. I know changing the radius would definitely changes the global rectangle but the outcome is totally off the chart. What is the cause of this?
(3,244 Views)
Spent some time checking and debugging and finally found out the problem: the value entering the IMAQ Convert Annulus to ROI was "NaN". So problem solve, please ignore this thread. 🙂
(3,241 Views)
