Machine Vision
View Image in a Tab Control using CVI
I am trying to embed several images in a Tab control in CVI.
Is it possible to attach an imaq vision image to a tab page and let windows/cvi do the show/hide image handling for me.
Or is it me who has to do the programming catching the EVENT_ACTIVE_TAB_CHANGE event?
I have seen the "Embed" sample to embed a imaq vision image in a parent window, but how does it work for tab controls?
Any help would be appreciated!
Robin
(3,353 Views)
Yes this is possible if you use a canvas and draw the image as a bitmap on this. See the NI-IMAQ CVI example 'snap canvas.prj'. The advantage is that the canvas is automaticlly redrawn but this is slower then the imgPlot function that only uses a region to draw directly on a panel.
Hope this helps,
Regards
Karsten
(3,290 Views)
Thank you for your reply.
Unfortunately canvasses are not an option because I would like to use the imaq ROI toolbox window. This is not available in a canvas.
Any other ideas?
(3,288 Views)
