Yes this is possible if you use a canvas and draw the image as a bitmap on this. See the NI-IMAQ CVI example 'snap canvas.prj'. The advantage is that the canvas is automaticlly redrawn but this is slower then the imgPlot function that only uses a region to draw directly on a panel.
