04-06-2016 05:24 AM
I'm doing a program for a vision machine with NI Vision Builder and i want to know how l could make the counter of #Pass and #Fail in the interface of inspection work automatically ?
04-07-2016 10:51 AM
Hello nouva,
Not sure if I understood your question. The inspection interface shows by default the number of Passes and Fails when you run it continuously.
Would you please add more details on what you want to accomplish?
AGJ
04-11-2016 01:00 AM
04-12-2016 01:44 PM
For Vision Builder AI to count the number of pass/fail, you must insert a Set Inspection Status step in your inspection.
Hope this helps,
-Christophe
04-13-2016 03:04 AM
Thanks for your attention.
I have another problem : i try to generet labview code from the code that i have develop with Vision Builder 2013 but it asks me to install Labview and vision development module 2012 or later although i have installed the 2 of them it doesn't work .
I would ask you if there is a solution for this problem ?
04-13-2016 05:51 AM
04-13-2016 05:54 AM
04-13-2016 06:04 AM
04-13-2016 03:44 PM
Nouva,
Could you please add screenshots of NI MAX showing the versions that you have installed for Vision Builder, LabVIEW, and Vision Development Module?
AGJ
04-18-2016 05:58 AM
Hi ,
you will find 3 screenshots of the labview,Vision Builder and vision devlopment.
thanks
