Machine Vision
VBAI Custom LabVIEW Interface minimum size limit
I have a LabVIEW VI selected as my custom VBAI interface.  I intend to run VBAI on a PC that is also running an executable (developed in LabVIEW).  Both the executable and VBAI have GUIs that must remain visible during operation.  With limited screen real estate, I am trying to make the VBAI interface just a bit smaller, but I seem to be running in to some sort of minimum window size limitation.  When I resize the VBAI window it pops back to a larger size.  I have not defined any such restriction on the LabVIEW VI that is being used by VBAI, so this must be a restriction in VBAI itself.
  1. Can I change the minimum size?
  2. If it is not changeable, is it published somewhere in the documentation?  What is the minimum window size?
Dan Press
PrimeTest Automation
(3,966 Views)
Accepted by Photon_Dan
Hello Dan,
VBAI does have a minimum resolution of 1024x768 minus one strip at the bottom for the tool bar and unfortunately you cannot change the minimum size for VBAI. Let me know if this answers your question!
Andy Chang
(3,948 Views)
Thanks for the reply.  That answers my question.  Of course, that leads to the feature request for future version that we should be allowed to make smaller interfaces if we want.
(3,943 Views)
Hello Dan,
I've already filed a product suggestion on your behalf and hopefully it will be addressed in future releases of VBAI.
Andy Chang
(3,923 Views)
