Machine Vision
VBAI 2011 takes too long to initializing inspections steps
I am working on VBAI 2011, and have 2 inspections separately to check the left hand side device and the right hand side device. Both of these inspections work very well. However, when I add these 2 inspections to 1 inspection, my VBAI seem like frozen. It took forever to Initializing Inspection Steps when I run it in the Inspection Mode, and no error pops up 😞
I am curious if anyone see this problem before, and how to fix it?
Thanks.
(4,171 Views)
Accepted by Hoa_Huynh
Would it be possible to post your inspection? If you don't want it on a public location, let me know and I can send you a private email.
Brad (National Instruments Vision R&D)
(4,168 Views)
Hi Brad,
Thank you for your quick response. I am sorry that I couldn't upload the file, and it also has some VI involved with as well, so I don't know if I can do it.
Since it doesn't work when I add 2 inspections to one, I decide go with the Select Inspection Function now; and it seems working well and doesn't take much time to load each of the inspection.
Thanks.
(4,164 Views)
Glad it's working for you. Not sure if you're aware, but you can right click in the state diagram and select "Import Inspection" to bring an existing inspection into your current inspection. This is the best way to merge two inspections.
Hope this helps,
Brad
(4,158 Views)
Thanks Brad,
That was how I did when I add 2 of my inspections by "Import" one to the other.
Hoa
(4,155 Views)
