Machine Vision
Using Labview to control a digital camera
That helped a lot. I think I have it now. Thank you so much for all of your help!
Melody
Message 11 of 31
(2,872 Views)
I am also trying to save multiple images to a directory. I was trying ot follow muks advice but I don't understand how to convert the while lop iteration and convert it into string. Is there something I am missing? I created a while loop and I don't know where to apply the changes. Also when I used the string to path function, I could not connect the path to a desired path. Shouldn't it be path to string?
Message 12 of 31
(2,862 Views)
how many bits are ur image? 8,24,32?
Message 13 of 31
(2,851 Views)
hope this helps
Message 14 of 31
(2,849 Views)
It works !!!!!
Thanks a lot. muks.
Message 15 of 31
(2,832 Views)
I am using a USB camera to take multiple images and it works fine. I am trying to make a modification on the image size by using the IMAQ set image button to conrol the X and Y resolution. The problem that I am having is whenever I put a button at different parts of the loop, it either flashes or the image gets blurry. I have attached the VI.
Message 16 of 31
(2,827 Views)
Hi mike,
              In the true case you are neither using a snap nor an acquire and in addition u r displaying the buffer image from imaq read.Use a acquire or snap in the true case as well.Define an individual buffer with distinct name there also.
Hope it helps
Dont Forget to Rate a good answer
Message 17 of 31
(2,812 Views)
Hi muks,
Thanks for the help. The program is working fine. I am tryin gto modify it some more. What I want to do now is to convert the image to an array, so that when I click on the screen I can see a value of the surrounding pixels. The emaple programs that I found deal with only saved images. Is it possible todo that with a live feed? I have tried to use the Image to Array example in the Lab view and also another example which I have implemented in the attached VI. Is there a link that I am missing?
Message 18 of 31
(2,788 Views)
Hey mike,
                I am again stressing a point.Buffer allocation in labVIEW is very important and that too when you are starting with a gray scale image and ending with a binary image allocating proper buffer is very very important.Allocate a buffer to hreshold function as well.Else it will use the only buffer that you have allocated initially.To confirm my ststement right click go to palate view in bianry.I hope u got it
Dont forget to rate a good answer.It will help us improve our answers
Message 19 of 31
(2,780 Views)
Hi muks,
I get the idea about having the buffer. My issue is how do I create a buffer? I tried to use the Imaq create and the Imaq acquire functions to create separate buffers but I am not seeing any changes. Can you please show me an example VI on how to create a separate buffer? If you can use the VI I posted in the previous message, that will really help.
Message 20 of 31
(2,759 Views)
