Machine Vision
Unknown network error
I'll try that...
Here's the advanced options I had to change from default after the adapters got reinstalled:
Jumbo Packets: Off -> 9014 bytes
Receive Buffer: 256 -> 2048 bytes   <-- We always used that value, do we really need this? What does it do? Could it be a problem?
Windows firewall: removed both adapters from the protected network connections in private and public profile
And I set the IP's again, obviously
Message 11 of 15
(1,538 Views)
Annnnd Unknown network error again. 😞
Message 12 of 15
(1,536 Views)
*bump*
The issue still happens regularly on both our systems...
Is there anything we could check to help find the issue? I don't know, like sniffing the packets going in and out or something? Maybe compare what the NI driver does vs what MAX does?
It's killing us 😞
Message 13 of 15
(1,482 Views)
Hey Samapico,
I would guess that by now you have,  but I wanted to make sure you had taken a look at this document:
http://zone.ni.com/devzone/cda/tut/p/id/5846
As far as watching packets, this is a tool that is sometimes used:
http://zone.ni.com/devzone/cda/tut/p/id/6746
As you can see, you can filter by IP address and figure out what is being sent and received by your computer.
Message 14 of 15
(1,465 Views)
Hi Samapico, did you found a solution to this problem?
Message 15 of 15
(1,300 Views)
