03-23-2007 02:12 PM
03-23-2007 04:18 PM
03-26-2007 08:21 AM
JohannS,
I'm not sure I understand your answer. Would you please explain a little more?
Note: I've also tried turning the LabVIEW USB drivers into a DLL. For some reason that doesn't work either. I built a real simple VI that returns the number of available USB devices (see attached code). Within the LabVIEW environment it correctly returns 1. When I build into a DLL and call it using a simple VB project I get 0 returned. Any ideas what's going on here?
Thanks again
03-26-2007 05:24 PM
