Machine Vision
Two GIGE basler ace cameras parallel monitoring
Hi.. I need HELP!
I have a few problems on ace basler cameras connection / acquisition.
1. I only can activate the camera from GENICAM SOURCE
2. I wanted to make parallel monitoring with 2 same ace basler cameras in my notebook, but I cant. All I get is
"The DLL could not be found" on both cameras.
3. It has no problem 2 cameras running at once on pylon viewer but acquisition speed is very slow.
The connection established on :
2 GIGE Ace Basler Cameras
1 Gigabit POE Switch
1 Windows 7 Notebook i7 QuadCore
Thanks b4!! Smiley Happy
(3,486 Views)
1. GENICAM SOURCE comes from Baslers Pylon.
2. Do the cameras appear in MAX? Are you able to snap an image there?
    Is the niimaqdx.dll located under Windows\System32?
Christian
(3,441 Views)
Is your network card supports jumbo frames?
Silver_Shaper | CLD
(3,434 Views)
