07-15-2008 06:59 AM
Solved! Go to Solution.
07-15-2008 08:30 AM
07-15-2008 05:20 PM
rpr,
If you mean to ask that Telecentric lens is going to eliminate image distortion due to as observed when using a CCTV type lens so that you do not have to use NI's calibration VI to correct the images than you are correct. Using a telecentric lens you should get a perfectly undistorted image, even at the periphery of the FOV.
Hope it helps.
07-15-2008 05:22 PM
07-16-2008 10:37 AM
