Machine Vision
Telecentric lens
Will using a telecentric lens eliminate the need for calibration?
(4,206 Views)
Accepted by topic author rpr
No it is not correct.Telecentric lens has nothing to do with eliminating calibration as far as i know. Telecentric lens can be used in application where 2 surfaces seperated by a small distance can be tried to brought into focus and telecentric lens can be used to increase resolution.In fact it is the other way round. Since u are bringing in different surfaces into focus u need to calibrate it more efficiently.Smiley Very Happy
(4,199 Views)
rpr,
If you mean to ask that Telecentric lens is going to eliminate image distortion due to as observed when using a CCTV type lens so that you do not have to use NI's calibration VI to correct the images than you are correct. Using a telecentric lens you should get a perfectly undistorted image, even at the periphery of the FOV.
Hope it helps.
(4,189 Views)
Schneider Optics has a non Telecentric lens line that has minimal distortion. But these are pretty expensive, about 2 to 3 times what you would pay for Fujinon or likes of it.
(4,188 Views)
Here's a little primer on what a Telecentric lens is:
(4,155 Views)
