I have 2 cards ,PCI-1409 and 6024E,the 6024E is used to acquired continious votage singals ,I am trying to trigger my camera using PCI-1409 from a RTSI signal driven by 6024E,i want the samples each time read and every frame are synchro.i want to know how creat a external trigger and config the trigger frequency as i want
It would be helpfull to know what your development enviroment is. Did you already take a look into the examples? If you are a LabVIEW User you will find an example to generate a pulse train with the DAQ board at \\National Instruments\LabVIEW\Examples\DAQ
Examples for image acquisition (triggered also) are at \\National Instruments\LabVIEW\Examples\Imaq
