Machine Vision
Some settings in IMAQdx .icd are not saved, some are ignored when NI MAX 19.5.0f0 opens the file
I'm looking for NI to resolve these problems in NI MAX with regard to the IMAQ to IMAQdx transition:
IMAQdx .icd file is missing the following attribute
Frame Grabber Attributes :: Encoder Controls :: Encoder Use IO Board Input
When NI MAX opens the .icd file, the following combination is ignored:
FrameGrabberAttributes::AcquisitionControls::TriggerSelector = "Line Start"
FrameGrabberAttributes::AcquisitionControls::TriggerSource = "Encoder"
FrameGrabberAttributes::AcquisitionControls::TriggerActivation = "Rising Edge"
FrameGrabberAttributes::AcquisitionControls::TriggerDivider = "1"
FrameGrabberAttributes::AcquisitionControls::TriggerMode = "On"
The Trigger mode will be "OFF" in NI MAX
NI MAX Saves the camera setting Trigger Mode "ON":
The .icd file says "ON"
Reopen NI MAX, the Trigger Mode is "OFF":
Trigger Mode OFFTrigger Mode OFF
Encoder Use IO Board Input is disabled.
Use IO Board not enabledUse IO Board not enabled
Camera files are attached
Message 1 of 1
(2,078 Views)
