Machine Vision
Smart Camera - Profile Selection
Can anybody tell me if there is a possibility of using the I/O Pins of the NI 17XX Smart Cameras for "Product Selection" or "Profile Selection" ?? If yes, which of those pins can be used and How?
For example, if there are 2 pins, it means i can store 4 different inspections on the Smart Camera. Based on the input bits, the specific Inspection number will be initiated when the Smart Camera restarts.
(4,827 Views)
Hello Medianix,
I will have to try this out on my end and get back to you. Would you consider the possibility of using a 'Run LabVIEW VI' step to get this done?
Vivek Nath
Applications Engineering
Vivek Nath
Machine Vision
(4,805 Views)
The answer is yes.
Are you programming the smart camera with LabVIEW or with Vision Builder?
If you're using the smart camera with LabVIEW, we provide VIs to read/write these IO lines.
If you're using Vision Builder, the functionality is built-in Vision Builder. Which version do you have?
-Christophe
(4,787 Views)
I want to use VBAI. Currently i have version 3.0, but if i am not mistaken, each smart camera ships with its own copy of the latest version of VBAI
(4,708 Views)
Accepted by Medianix
Since the Smart Camera I/O returns booleans and the Product Select State requires a number or string to choose which product to select, you could use a System Global Variable and at the end of each of your inspections update this with the state of the two input lines on the Smart Camera. Then, in the Product Select State, you can read the value of these two System Globals in the attached Run LabVIEW Step (which has already been compiled for the Smart Camera). This VI will convert the two boolean values to a number (0 to 3) which can be used for product select.
Hope this helps,
Brad
(4,692 Views)
To clarify your second question, each smart camera DOES ship with the latest version of VBAI.
Vivek Nath
Machine Vision
(4,671 Views)
Dear Brad and Vivek, many thanks for your responses. I havent had a chance to check out the VI by myself, but your ideas make me clear now.
(4,642 Views)
