Machine Vision
Shortcut with start parameter to start VBAI in ispection interface?
Is there any possibility to start the a VBAI file with ispection interface instead of configuration interface via a shortcut with start parameter?
I know the "Start Inspection When Launched" possibility. The problem is, that we use two different programs on this PC and I would like to make them both available via shortcut from the desktop and both to start in ispection interface.
Thank you.
(3,173 Views)
Accepted by topic author PaulFreudenthaler
take a look into the VBAI help in the Getting Started topic. The \inspect  [inspection_path] option seems to be what you are looking for.
Kind regards
Andreas
Andreas Gareis
Senior Applications Engineer, NI
Certified LabVIEW Developer & TestStand Architect
(3,135 Views)
It works as expected. I create shortcuts on the desktop which will start the linked inspection. I can even run several inspections paralell.
Thank you!
(3,083 Views)
