â10-10-2006 03:19 AM
Hello to all,
I just started to use vision and I had a question. If I use edge detection to determine the center of a cylinder at the bottom and at the top how can I use instruct edge detection to preform edge detection between the 2 centers?
Guus
â10-10-2006 08:32 AM
Your question isn't very clear. Can you post an image that will clarify your problem? It sounds like maybe you want to use Find Circular Edge, but it is hard to tell.
Bruce
â10-10-2006 08:56 AM
Sorry I wasn't that clear but I will try to clarify. I have 2 distinct edges A and B (in the .doc you can see the picture). Than I use edge detector and caliper to determine the center of 1 and 2, and the center of 3 and 4. If vision has determined the centers I want vision to do an edge detector between 5 and 6. This is done because I want to do an edge detection in the center of the rod but the rod is not always in the same place.
Guus
â10-10-2006 09:05 AM
â10-10-2006 09:10 AM
â10-10-2006 09:28 AM
â10-10-2006 09:35 AM
Well I still use the Evaluation version and it doesn't allow me to build a VI in labview. But is it possible to let caliper give the coordinates to edge detection so it automatically draws the line between them and looks if there are edges?
Guus
â10-10-2006 10:49 AM
