Online shopping is currently unavailable.
Please contact us for help or try again later.
Machine Vision
Scan Bitmap
hello,
i'd like to produce an anaglyph picture. therefore i switch between two channels while the acquisition is running.
in the callback function i paint the two images in two different HBITMAPs. this happens not until i have both images
(this means, that the while-loop has to run twice before plotting). when i got the two HBITMAPS, i read the COLORREFs wit GetPixel().
In a new HBITMAP i set the Pixel with setPixel(...,RGB(RValue(colorref1),0,BValue(colorref2))). This HBitmap is then
drawn with imgPlotDC.
the problem is, that SetPixel() is very slow, so that my frame rate goes down to 0.58 f/s...
has anybody an idea how to solve this problem?
best regards,
malte
(3,358 Views)
If I understand your nedds correctly, I would propose you multiply the two pictures with different coefficients and then add them.
Cheers
It would be nice if you take the time to rate this answer
http://www.machinevision.ch
(3,346 Views)
