04-28-2010 02:19 PM
04-28-2010 02:23 PM
04-28-2010 02:42 PM
The existing camera is a monochrome, board-level 1.3MP camera with an active area roughly 5x5mm. I figure that sets my minimum criteria. I can go a little smaller on the active area, and I can certainly go bigger on the pixel count.
But what I'm really looking for is a general suggestion as to what manufacturers fully support DirectShow or perhaps provide LV drivers. From what I've read on this forum, Mightex cameras have a lot of problems.
And no, I didn't select the camera originally...
04-28-2010 02:50 PM
That's a good start on specs...
Do you want to stick with board-level or also consider housed?
Do you want to stick with USB, or also consider 1394b and/or GigE Vision?
04-28-2010 03:11 PM
04-29-2010 01:38 PM
Hi Greg,
It's hard to recommend a specific model, because our IMAQdx supports all DirectShow compliant cameras. That's why NI doesn't have a specific list of supported cameras. Of course, as you've noticed, some "DirectShow" compliant cameras may have some issues with their drivers.
What I can tell you is that I've worked with Creative Labs cameras (VF0330 and VF0320), and they seem to work pretty well, haven't had any issues up to this point.
Logitech also should be pretty good.
04-29-2010 03:53 PM
