Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
08-20-2012 03:29 PM - edited 08-20-2012 03:36 PM
I'm looking for an efficient way to remove particles from my binary image that are overlapping.
Image 1 is the current thresholded frame
Image 2 are the particles that are bad
Image 3 is the combination of image 1 plus image 2
I want to remove the particles that are "overlapping"
Any efficient ideas?
Branson
PS Images are in binary form, so you need to open them in IMAQ to see them.
Red = binary value 1
Green = binary value 2
Blue = binary value 3
Solved! Go to Solution.
08-20-2012 04:01 PM
Do you mean you want to remove the red particles that are touching green particles?
Bruce
08-21-2012 05:38 AM
I guess you are trying to do a binary reconstruction, have a look at the IMAQ Binary Morphology Reconstruction: http://zone.ni.com/reference/en-XX/help/370281P-01/imaqvision/imaq_binarymorphology_reconstruction/
Provide the function with your "bad image" as the marker image.
Hope this helps
Regards
08-21-2012 06:26 AM
I want to keep the particles that are only red, and I want to remove the particles that have green or blue.
08-21-2012 07:47 AM
Thanks toto69!
IMAQ Binary Morphological Reconstruction
Wired Image 1 to Image Source
Wired Image 2 to Image Marker
Result was any particle from image 1 that touches the particles in image 2.
From there, I IMAQ Or'd Image 2 with the Result,
and then subtracted that result from my original Image 1.
Awesome!!
