Hello larryb.
Thanks for contacting us. I'm not exactly sure what you mean by 'horizontal frame fragmenting,' so I will speculate that it just means that your images are skewing in some fashion when there is motion in your image.
Are you seeing this behavior when you do a grab acquisition in Measurement and Automation Explorer (MAX)? If so, what is the frame rate of your camera?
Depending on whether you see the behavior in MAX or not, we may or may not be able to do anything to the LabVIEW code to fix the issue. Take a look at your processor usage when you run the example as well to see if maybe it has anything to do with that.
Again, if you can clarify 'horizontal frame fragmenting' a little bit, as well as if you see the issue in MAX, then we can go fro
m there!
Colin C.
Applications Engineering
Colin Christofferson
Community Web Marketing
Blog
