Machine Vision
Problem with FireWire (IEEE1394) speed - no more then 100Mbit/s
Hello guys,
I have a problem with the speed of the FireWire bus.
I am using a ImagingSource camera model DFK21BF04, its a CCD FireWire color camera.
The problem appears when I want more then 15fps in BY8 (black and withe) mode and more then 3,75fps in UYVY (color mode). I think that the main problem is that I cant set a higher speed then 100mbit/s.
The driver is NI-IMAQdx IIDC Digital Camera.
The computer I am using is a Matrix MXE - 1020S. It is an industrial computer with 2 FireWire (9pin) ports.
The camera has a 6pin(400Mbit/s) connector and the computer has a 9 pin connector (800mbit/s).
So this should work on 400mbit/s.
So when i want a higher fps rate an error appears. (Picture 3)
Please help me.
Tnx
Message 1 of 8
(4,447 Views)
Hi BordoSlo,
Which OS is installed on your industrial computer? Similar behavior was reported already due to Win7 IEEE1394 driver issue.
The forum post under this link, talks a bit more in details about this issue. It seems that using the Legacy 1394 driver solved the isse for some customers.
I hope this will help.
Barna D.
Message 2 of 8
(4,437 Views)
The OS was XPsp2 until I found a possible solution in the industrial computer manual that the 9pin FireWire connector may have some problems in XPsp2 and that there should not be any problems if I upgrade the OS to XPsp3. So now the OS is XPsp3.
So I plug in my camera (ImagingSource DFK 21BF04.H) with a 6pin FireWire connector to the industrial computer which has a 9pin FireWire connector and i cant get more.
 then 100Mbit/s in MAX and also not in Vision Buildera AI 2009 SP1.
Marko B.
Message 3 of 8
(4,433 Views)
Download the Basler Pylon camera drivers and install them.  You don't need to install the SDK and other stuff, just the drivers.  I am pretty sure this will correct your speed issues.
Bruce
Bruce Ammons
Ammons Engineering
Message 4 of 8
(4,419 Views)
I don`t know why Basler drivers would help, but I tried it and they don`t.
Also I have a ImagingSource USB camera that has a speed of 150 fps acording to the datasheet, but I can only change the picture format and not the speed that can only be 30 fps.
http://www.theimagingsource.com/en_US/products/cameras/usb-cmos-mono/dmk22auc03/
In MAX I can`t even change drivers for USB camera. There is no driver menu when right-clicking.
Cameras, bus or drivers ?
Message 5 of 8
(4,400 Views)
When you do not get the 400Mbs the problem looks like XP. I Thought it was solved in windows7
Problem speed off IEEE-1394 when using XP SP2:
http://support.microsoft.com/kb/885222/en-us
After you update your computer to Microsoft Windows XP Service Pack 2 (SP2),
the performance of your 1394a or 1394b FireWire devices may be greatly decreased.
A digital camera that uses S400 speed is an example of such a device.
We use AVT camera's and PCI-express and AVT driver to do this. But we do not use Windows7 only XP
http://www.alliedvisiontec.com/de/corporate/presse/pressemeldungen/pressemeldung/article/new-firewir...
But i am not sure it will work with your camera.
NI somewhere had a prosilica patch
http://digital.ni.com/public.nsf/allkb/2243D57B9EEF22B686256FB7005E23C1
Hope this will help you.
With kind regards,
Toine Roetman
Message 6 of 8
(4,384 Views)
The WinXP SP1 rollback 1394 patch should do the trick, it worked for us...
Message 7 of 8
(4,354 Views)
The solution from this link http://support.microsoft.com/kb/885222 will work,
not the exe, but manual registry edititng.
After edit registry you will be able to acheive 400Mbit/s maxumim. If you want to acheive 800 you should rollback the drivers from SP1 as LabUseful wrpte.
Message 8 of 8
(4,314 Views)
