Machine Vision
Problem creating RT with 8.6
Hello,  all
I'm trying to create a RT PC with the new package "Labview8.6" before this when i needed to create a RT PC i used the Package of the Labview 8.5.1 and normally its work ok.
At this moment im trying to create a RT PC with the 8.6 with the same hardware that i use when i create with the 8.5.1, but the problem is when i install the software vision RT to the my RT machine if i only put the software of labview 8.6 he create the RT without any problem and he works, but when i install the vision RT and when i reboot, the RT freeze and dont work.
Anyone knows why this hapenning.
Thanks for the help.
Message 1 of 8
(4,382 Views)
Hi RMPG,
What boot disk/USB key are you using to format the system prior to installing LVRT 8.6 on the target? I believe there is a known issue where you must format the system with a LVRT 8.6 USB key (rather than an older one) prior to the install or else it will lead to a boot-time hang.
-Eric
Message 2 of 8
(4,380 Views)
Hi RMPG,
Did the solution of Eric resolve your problem? Or do you need further help?
Olivier L. | Certified LabVIEW Developer
Message 3 of 8
(4,343 Views)
Hello again,
Before all, thanks for the help.
But unfortenely, i still have the same problem, because as i said in the first post, i dont have any problem creating the RT, i only have problem when i put the Vision RT software to the RT. I use the disk boot to create the RT, because with the hardware i use i cant use the usbboot.
Thanks again
Message 4 of 8
(4,338 Views)
Just to be sure, did you well use the disk boot created from RT 8.6?
As Eric said, there is a known issue filling with the issue you are talking about, you could find infos in the following link:
http://digital.ni.com/public.nsf/allkb/E3A832C2E441CC91862574A300557EAC?OpenDocument
I would ask you to reformat you RT desktop target with the disk boot created from RT 8.6 and to try again, and let me know.
Message 5 of 8
(4,335 Views)
Hello again, Olivier L
Unfortenely, when i tryed to create the RT with the 8.6 i create the disk's boot with the package 8.6 already.
Thanks again
Message 6 of 8
(4,333 Views)
Hi RMPG,
I wanted to test myself if I reproduce your issue, then I realized that it was not possible to create a bootdisk with RT 8.6, you can only create a USB key.
When trying to create a boot disk or format disk, you only have option for 8.5 or 8.5.1 but not 8.6.
I think your problem is coming from here. As we told you, you faces problems when you boot you RT desktop with 8.5.1 version and installing RT 8.6 and Vision 8.6 on this RT target.
Could you please have a second look to the boot disk you are creating?
Message 7 of 8
(4,324 Views)
Hi again,
You are right, it only have the boot disk of the 8.5.1 and not the 8.6, i will try to use the USB boot.
Thanks again
Message 8 of 8
(4,305 Views)
