11-17-2008 11:10 AM
11-17-2008 11:14 AM
Hi RMPG,
What boot disk/USB key are you using to format the system prior to installing LVRT 8.6 on the target? I believe there is a known issue where you must format the system with a LVRT 8.6 USB key (rather than an older one) prior to the install or else it will lead to a boot-time hang.
-Eric
11-24-2008 02:52 AM
Hi RMPG,
Did the solution of Eric resolve your problem? Or do you need further help?
Olivier L. | Certified LabVIEW Developer
11-24-2008 04:27 AM
Hello again,
Before all, thanks for the help.
But unfortenely, i still have the same problem, because as i said in the first post, i dont have any problem creating the RT, i only have problem when i put the Vision RT software to the RT. I use the disk boot to create the RT, because with the hardware i use i cant use the usbboot.
Thanks again
11-24-2008 04:47 AM
Just to be sure, did you well use the disk boot created from RT 8.6?
As Eric said, there is a known issue filling with the issue you are talking about, you could find infos in the following link:
http://digital.ni.com/public.nsf/allkb/E3A832C2E441CC91862574A300557EAC?OpenDocument
I would ask you to reformat you RT desktop target with the disk boot created from RT 8.6 and to try again, and let me know.
11-24-2008 05:09 AM
Hello again, Olivier L
Unfortenely, when i tryed to create the RT with the 8.6 i create the disk's boot with the package 8.6 already.
Thanks again
11-24-2008 08:26 AM
Hi RMPG,
I wanted to test myself if I reproduce your issue, then I realized that it was not possible to create a bootdisk with RT 8.6, you can only create a USB key.
When trying to create a boot disk or format disk, you only have option for 8.5 or 8.5.1 but not 8.6.
I think your problem is coming from here. As we told you, you faces problems when you boot you RT desktop with 8.5.1 version and installing RT 8.6 and Vision 8.6 on this RT target.
Could you please have a second look to the boot disk you are creating?
11-24-2008 04:03 PM
Hi again,
You are right, it only have the boot disk of the 8.5.1 and not the 8.6, i will try to use the USB boot.
Thanks again
