Machine Vision
ParticleFilter4 parameter error while program running
    I use CVI and VDM8.6, I had installed the VDM8.6 patch package, and there is no error while  program compile, but when run the program, there is error occured, the error message is as attached image showed;
    also I had another question: should I place ParticleFilter() before ParticleCount() or after ParticleCount?
Thanks in advance,
(3,472 Views)
Accepted by samliu321
The line above the marked line in your screenshot just defines a pointer - but no memory for the data structure.  That's why you get an access violation.
(3,467 Views)
Dear Guenter,
    Problem solved, Thank you very much!
    I made mistake on  the input  pointe parameter, when the pointer is used as output parameter then it no need to assign memory.
Sam Liu
(3,463 Views)
