Machine Vision
Particle separation: Blob & Line
Hello all,
here is my problem: I have to determine & separate particles, but sometimes I end up in the situation when the image is shifted from the initial background used for subtraction, thus resulting in something like on the image attached - after subtracting the background, thresholding and applying mask.
Tings to mention:
1 - the "line" is not straight;
2 - the particle touches "line" strongly, so that 4-connectivity does not help
3 - IMAQ Separation didn't work as well.
4 - it is binary, threshoded to the maximal possible not destroying the particle
5 - Erosion 2 even 3 does not work here, higher is not possible - it might destroy the other small particles to be detected
Any ideas hot to programmatically cut the particle from the line and remove the line afterwards?
Many thanks in advance!
Ilya
(2,549 Views)
DO NOT POST IN THE THREAD
this is a duplicate of http://forums.ni.com/t5/Machine-Vision/Particle-separation-Blob-amp-Line/m-p/3662935
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(2,521 Views)
