Machine Vision
Particle Analysis Sub-Pixel Resolution?
I've tried to find literature about the resolution of NI's Particle Analysis.
I read it goes up to 1/10 of the original resolution as far as rectangle boundaries, but does is apply to all of the parameters as well?
Thank you,
(4,720 Views)
Hello Simply Me,
Could you clarify a bit more on what you mean by the sub-pixel resolution? Could you also point me to the document that said it would go up to 1/10 of the original resolution for rectangle boundary?
Andy Chang
(4,686 Views)
Hi Andy,
I've found a number of resources that state that particle analysis have a sub-pixel accuracy:
http://www.ni.com/vision/software.htm
and :
http://www.google.com/url?sa=t&source=web&cd=4&ved=0CCsQFjAD&url=http%3A%2F%2Fwww.cadfamily.com%2FDo...
This one says that it has up to 1/10 of a pixel, but I'm not sure it's NI's
(under NI Vision Development Module):
http://www.movimed.com/Visionsoftware.htm
It's important for me to know if the vi I've attached have a sub-pixel accuracy or not (and if it has, what is it).
Thank you,
(4,683 Views)
Accepted by simply_me
Hello simple_me,
The subpixel accuracy is actually about 1/25 of a pixel. You can find a detailed information in the NI Vision Concepts Help by navigating to Start > Programs > National Instruments > Vision > Documentation > NI Vision > NIVisionConcepts
21523i3C8326F09F34A63D
Andy Chang
(4,640 Views)
Thank you Andy, I wasn't aware of the documentation files.
(4,636 Views)
