Machine Vision
PULNIX TM-6740CL FLICKERS
Pulnix TM-6740CL camera flickers in MAX using PCI 1428 card, checked with both IMAQ 3.1.1 and IMAQ 2009 drivers, same issue. When using A2x2 binning it faults out also. Is there any setting need to be adjusted to make it work?
Message Edited by ni_user on 12-22-2009 07:07 PM
(4,184 Views)
Are you using any trigger and if so how are you triggerring it in cam or frame grabber?
(4,176 Views)
Everything is factory setting both CAM and Frame grabber PCI1428. No triggers.
(4,162 Views)
Check your cable. Did you try replacing them?
(4,144 Views)
