Machine Vision
PCO
I have PCO Dimax S1 High speed camera and NI-1429 Cameralink board.
I'd like to use 1429 board to control the camera, but the error 0xBFF60022 appeared when I try to control in NI-MAX.
If I use example which provided by PCO to control the camera, it is not work. The example is written by IMAQ.
However, if I use another example which provided by PCO with C, it is work.
Due to I must combine the Dimax S1 and NI-FPGA card together, I must the use IMAQ to control the camera first.
Then using TCP to replace the communicated port.
Do you have any methods to solve this problem?
(5,341 Views)
I could not find the camera file (.icd) of PCO in NI-IMAQ document. Therefore, NI-1249 could not support the camera.
You can check it in the path: C:\Users\Public\Documents\National Instruments\NI-IMAQ\Data
That might be the reason you cannot countrol your camera with NI-1429 board.
I will recommend you to contact the camera company, looking forward if they can provide you the camera file for their cameras.
Dave
(5,320 Views)
