Machine Vision
PCI1424 - invalid buffer with triggered onboard memory aqcuisition
I need to capture 2 images at a very short interval using a PCI-1424 and a Kodak/Redlake camera. I have to use the onboard memory to grab the images. Using the example
\National Instruments\CVI\samples\IMAQ\Ring\ring onboard mem.prj, I added the following code in 'int CVICALLBACK Ring'
// Open an interface and a session
   imgInterfaceOpen (intfName, &Iid);
   imgSessionOpen (Iid, &Sid);
// ADDITIONAL CODE fOR TRIGGERING
res = imgSessionTriggerConfigure2 (Sid, IMG_SIGNAL_EXTERNAL, 0, IMG_TRIG_POLAR_ACTIVEH, 5000, IMG_TRIG_ACTION_BUFFER);
When the program is executed, a timer checks if a valid buffer is available:
int CVICALLBACK Imaq_loop (int panel, int control, int event,
  void *callbackData, int eventData1, int eventData2)
 /* definitions here */
 static unsigned int lastBufNum = 0xFFFFFFFF;
 switch (event) {
  case EVENT_TIMER_TICK:
   imgGetAttribute (Sid, IMG_ATTR_LAST_VALID_BUFFER, &currBufNum);
   if((currBufNum == lastBufNum) || (currBufNum == 0xFFFFFFFF))
    return 0;
On my old NT system with NI-IMAQ 2.2, the value of &currBuffNum form imgGetAttribute was always 0xFFFFFFFF until the first trigger was received, so basically, return 0; was executed up to the first trigger.
On XP with NI-IMAQ 4.0 the first value of currBufNum is always 0 and the call
imgSessionCopyBuffer (Sid, currBufNum, CopyBuffer, FALSE);
waits until the trigger occurs... with the side effect, that the image is not really in buffer 0.
Is this difference between IMAQ2.2. and 4.0 intentional or am I missing something?\
Regards
Roland
(3,363 Views)
Hi Roland,
Are you able to get the example to work with triggering?  Or is the buffer number difference causing problems?  As to how the IMAQ driver allocates buffers, NI-IMAQ Memory Allocation is a helpful article. In terms of what has changed with the IMAQ driver specifically, What's New with NI-IMAQ details everything from IMAQ 2.5 to the current version (4.0).
Marti C
Applications Engineer
NI Medical
(3,325 Views)
Accepted by topic author Rolboes
I found a workaround. I use the function
ImgErrCode = imgSessionStatus(sessionID,&status, &currBufNum);
instead of
ImgErrCode = imgGetAttribute (sessionID, IMG_ATTR_LAST_VALID_BUFFER,&currBufNum);
In this case, currBufNum is 0xFFFFFFFF until the first image is recorded.
Roland
(3,261 Views)
