Machine Vision
Output channel on NI PCIe-1427?
Hi!
I have NI PCIe-1427 framegrabber, that have beside cameralink connector (MDR 26-pin) also 15-pin D-SUB connector.
In my application I will have one digital output channel, so I would like to know if it is possible to configure any channel on this 15-pin connector as digital output channel?
Also an suggestion how to do this will be very helpfull.
Thanks in advance!
andrej
(3,468 Views)
Hi Andrej,
There are 4 Digital lines on the 1427.  If you look at the user manual in Fig. 3-2, 3-3, and table 3-1 you can see what each pin is used for.  In LabVIEW there is a function called IMAQ Generate Pulse3.vi using this vi you can output a digital signal.  There is an example in LabVIEW that uses this vi called LL Pulse Generation.vi.  I would look at that example to get started.  I hope this helps.
Have a great day,
GG
(3,450 Views)
