Machine Vision
OCR in closed text
Hi Guys,
I have a question based on the Image attached. I am trying to do OCR through the text it says System Reset using the NI vision Assistant. It looks like the text is too closed and always missed a character.
Would someone with more experience advice how to tackle this issue?
Fernando H. Solórzano
HW Automation Test Engineer
(4,951 Views)
Hi
Are you trying to read the characters or confirm that the correct word is on the correct button? If it is the latter then pattern match within a tight region will confirm presence/absence. The characters and spacing are very small, a higher resolution image would be better.
Mike
(4,946 Views)
I am trying to confirm that the correct word is on correct button. I am acquiring this image from HDMI so I dont know if the is possible to make any modification..
Thanks for your repply.
(4,919 Views)
Accepted by Ferchu
Teach the pattern match the word in the button and then set the search region of interest to be the button. You should have a really high score as your signal is digital, so set the threshold quite high on a match. If you have similar words/phrases "XXX setup" and "XXX signal" then split the pattern match into two so that the difference is highlighted. "XXX" should be tested and then the other word. If either one has a big difference then you have a problem.
Mike
(4,903 Views)
Thanks Mike, I appreciate your response and help.
(4,852 Views)
