Machine Vision
No video at startup of Labview program gives me error. How do I automatically reacquire periodically?
I have a PCI 1411 running Labview NI-IMAQ 3.0. I am hooked to a military infrared device. I need to be able to power on the camera with a Labview program. Therefore, I have no video at startup and need to be able to acquire once I start. Now, if no video is running when I start, I never see video and I get an acquisition error. What should I do? Thanks!
(2,756 Views)
This depends on how you plan to power on the camera. Are going to switch the AC power to the camera, toggle a digital enable line, or send a serial command? Without knowing how this camera works it's difficult to say how to turn it on, but more than likely LabVIEW (with the right hardware) will acommodate your camera.
Once you have the camera powered, you can proceed with the acquisition as normal. If there's no way to know whether the camera is powered, you could just call a snap command in a loop periodically and exit when you no longer see an error or you get tired of waiting.
Cheers,
Brent
(2,756 Views)
